Workholding question
(JONATHON D GREEN) #1
I’m looking for a solution to clamp an 8"x 8" x 0.25" piece of Aluminum onto my table. Anyone have a suggestion that would be easy to swap plates to keep things running?
(William Adams) #2
Is running a compressor and using a vacuum an option?
(JONATHON D GREEN) #3
No to vacuum, as I’ll be cutting through the plate. I’m personally biased towards mechanical clamping.
(Adam X) #4
If you’re doing repeated work on the same stock size, I’d machine an 8x8 pocket into a chunk of MDF, attach the MDF with some hot melt and Roberts your Mother’s brother. Little bit of double-stick tape on the AL bottom and it won’t go anywhere. Plus perfect registration every time.
(Dan Nelson) #5
I cut a piece just that size recently. I screwed it down with wood screws into a larger piece of sacrificial MDF, then clamped the larger MDF using normal clamping. If you had a couple pieces of MDF the same size, and a way to set them into the same place every time (dowel pins, etc.) you could swap that way and have the next ready to go. I usually make 1/4" dowel pin holes with the SO3, I drill the holes into MDF, then set the first piece just where I want it, run the same NC program to drill holes in that (and every subsequent piece) in the same place, then place 1/4" steel dowel pins in and always have the same position, works good for 2 sided jobs too if you place the holes along a center axis. Or as Adam pointed out above, you could cut a pocket the same size as your stock and use tape.
Dan
(JONATHON D GREEN) #6
Thanks for the suggestions.
I’m thinking of an oversized scrap board with a pocket sized for the stock, and a cam pin to lock the stock in place.
This sounds like an interesting project.
Runs off to drawing cave to make plans for tooling…
