Posting some of the things i’m working on. Milling pink foam, using RhinoCAM to generate my toolpaths. 1/4" ball nose. these pieces are not flip milled but i have others that are. i’ll post some more images later in the month as this particular sculpture / installation gets close to the finish line. the surfaces are from a 3D scan of a house that i did using Photoscan - which is my main workflow for generating scans right now. I’ll be milling other elements of this house and multi part pieces.
How do you feel about RhinoCAM vs say MeshCAM? And I’m intrigued about what you’re doing with scanned parts of a house… hmmmm. Looking forward to seeing it.
RhinoCAM gives you more control than MeshCAM and can work from CAD generated in Rhino. I like both of them - but I use RhinoCAM pretty much 100% of the time. i have MeshCAM mostly as a backup.
