z axis stepper motor is stuttering during operation. Checked all connections and mounting. Motor moves freely when not powered. Any help appreciated.
Please check your wiring — usually awful noises are usually caused by a wiring fault.
If that doesn’t address it, please contact support@carbide3d.com
I’ll give it a shot. Thank you.
Thanks, after a little investigating I found there’s no continuity on the green wire of the extension cable for the z motor. I’ll send an email to carbide3d support and hopefully it won’t take too long to get a replacement.
I have the same issue — I’ve contacted support but don’t seem to be getting any movement in getting a new harness sent my way. Any potential problems in cutting the connectors and building a new wiring assembly myself?
If I have the right ticket, you’ve been sent a replacement — just waiting on the shipping company to scan it into their systems. I’ve added a note that this should be checked on.
The Molex connectors are a big nod towards convenience — one can wire up the machine in any way that one wishes so long as there aren’t any solder joints where they would be flexed and stressed. The community has some notes at: https://www.shapeoko.com/wiki/index.php/Electronics#Wiring and https://www.shapeoko.com/wiki/index.php/Parts#Wiring
