I am running into inconsistencies using the Z probe feature of the UGS. About 50% of the time it works as expected–bit hits the surface and is retracted (quite a bit) with the proper math done to Z. About half the time it retracts a very small amount and then plunges into the bed as if everything was mirrored on Z. First theory was that maybe I started with a Z too low before initiating the probe. This does not appear to be the problem.
Can’t figure out a pattern as to why this is happening(?)
Using UGS Product Version: Universal Gcode Platform 201609300101
Sounds like mechanical to me. It’s fairly common for a z axis to lose steps when moving up due to gravity. Check you linear rails and leadscrew for abnormal wear and try cleaning and lubing them per manufacturer guidelines.
