1 inch surfacing, 5/8 inch ball, and 1/4 inch upcut bits for the SO3?
I’m trying to replicate these cutting paths on the Shapeoko 3 XL using the Dewalt 611: Improvements On Cam Strategies for CNC machining Guitar Bodies with Fusion360 - YouTube
He uses the following bits for the following cuts:
  1. 22 mm flat end mill for
    1. 2D contour (guitar body outline)
    2. Adaptive clearing (roughing the body)
  2. 16 mm round nose for
    1. Scallop (smoothing the body)
  3. 6 mm for
    1. Finishing pockets and drill operations
I would like to use the following bits:
  1. Instead of 22 mm flat end mill
    1. 1 inch flat end mill (mainly because I can’t find a 5/8 inch surfacing end mill)
      1. https://www.amazon.com/Whiteside-Spoilboard-Surfacing-Router-Shank/dp/B071748JQN/ref=asc_df_B071748JQN/?tag=hyprod-20&linkCode=df0&hvadid=198077680239&hvpos=&hvnetw=g&hvrand=17791823230158411987&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9032443&hvtargid=pla-357583616788&psc=1&region_id=674469#customerReviews
      2. or https://www.amazon.com/gp/product/B07ZP5RXRP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  2. Instead of 16 mm round nose
    1. 5/8 inch round nose
      1. https://www.amazon.com/Router-Diameter-Wolfram-Woodworking-Cutting/dp/B09LD4V54Z/ref=sr_1_94?crid=2LCSBRIGM8LIT&keywords=1%2F4%2Binch%2Bshank%2Bround%2Bnose%2Bbit&qid=1675827018&sprefix=1%2F4%2Binch%2Bshank%2Bround%2Bnose%2Bbi%2Caps%2C149&sr=8-94&th=1
  3. instead of 6 mm
    1. 1/4 inch spiral uncut
      1. https://www.amazon.com/Whiteside-Router-Bits-RU2100-Standard/dp/B000K2BGNS/ref=sr_1_34?crid=1SHJU6PE01L4A&keywords=1%2F4+inch+shank+upcut&qid=1675826651&sprefix=1%2F4+inch+shank+upcut%2Caps%2C211&sr=8-34
Do those bit sizes look like reasonable asks for the SO3?
Thanks Joe - so if you were doing something like a Les Paul with a carved top, would you use the 1/4 flat end bit for the adaptive clear to shape the carve top, then clean up with the ball end bit?
The 1" as @Ensalaco said uses a very shallow doc. The 1" can easily burn the surface and you would need to sand it off.
Thanks Joe, that makes sense. And I’m trying to be efficient, but I’m also not mass producing guitars so speed is not the be-all end-all for me.
So sounds like the best roughing options would be either:
  1. 1/2 inch end mil, 1/4 stopover, .040” step down; or
  2. 1/4 inch end mil, .040” step over, .040” step down
Would feeds/speeds be similar for both?
Love it, thanks! Still getting the machine squared, but when I do I’ll try that approach.
