I have a need to run a bit which only comes w a 10mm shank. Any ideas where to find 10mm collett for carbide router?
The largest collet available for the Makita RT0701 (which also fits the Carbide Compact Router, but is not supported) is 3/8", just a bit over 9.5mm.
To use a 10mm shaft tool you will need a spindle which supports larger collet sizes, say an ER-16 or ER-20 system.
