Yes, please post or send that and we’ll try to work through this with you.
Ok great. Toolpath 1 is my pocket, Toolpath 2 is (what I want to be) my finishing pass going counter-clockwise.
test.c2d (5.6 KB)
OIC.
The outside path is different, since it’s trying to describe an optimal path around the corner.
Instead you’ll have to manually draw in the necessary shape in the correct direction — I believe I got it right in the attached.
test_no_offset.c2d (9.9 KB)
I believe I tried this already - the issue with the no-offset toolpath is that is runs in the same direction as the pocket toolpath, clockwise, right?
Is there anyway to tell the machine to cut the no offset path counterclockwise?
The No offset toolpath should run in the direction it was drawn — I drew that one by hand, so it out to be correct. If not, mirror it horizontally.
Ahh okay! Thank you. I did not know that - will try to cut tonight. Appreciate the help, Will!
