I have been noticing that when cutting a 3d project in pro, the outer edge of the project results in steps each time the bit is changed for a smaller diameter.
It seems like each cut is on the Border line instead of inside the line so each time a new/smaller bit is used half the diameter shows, outside the set dimension as an unwanted step.
