3d Circle Help for my clock
Hello All, How would I change this inner circle to match the fonts with out altering the contents in the circle ?
Every time I change the perimeters of the circle the contents of the circle disappears or becomes altered. I just want the (line) of the circle to be rounded such as the text and numbers are…
Thanks.
You want the inner circle raised or lowered? You want the text in the circle raised like the numbers?
What toolpath are you using and what do you have selected when you create it? You may need to either select the circle and the text or add an additional circle to get the desired effect
Is it grouped?
Please upload your .c2d file.
I am not at the tool path part just yet, I want the circle (line only) raised…
nothing is grouped in the file , just need the circle (line only) raised
I am ok with the text thanks, kind of figuring that out fairly well. However, raising the inner circle line is driving me nuts, tried playing with all perimeters and no success…
v/r
It’s hard to understand what you’re asking. Do you want the cross section to look like one of these?
It sounds like you’re asking for the 2nd example. If so, you can’t just raise the circle, you’d have to add another circle next to it.
