Hello all,
I am running Carbide Create Pro build 778. I was wondering if when doing a 3d preview of the model(s) if there is a way to change the preview material. Mine is a red wood texture which for me makes seeing the details very difficult. I know that under the tool path simulation you can choose a material there, but I am not finding a way to change it on the 3d model view.
In 3d previews some of the material choices are just not good. The redwood default is terrible. They hide 3d preview and make it hard to tell what you are going to get. On the 2d simulations I use the aluminum for the same reason that some of the material choices obscure your view. If I need to send a preview to someone I am making something for I use the aluminum even though I will be cutting wood. The preview in Carbide Motion is pretty good to see what is going to happen but you have to have CM hooked up to your machine to see the preview.
