I’ve tried to initialize for the first time and continue to get the same error message. I was trading emails with support last week and they determined that my controller might be bad. I just plugged the new controller in with the same issue.
I’ve tested all my homing switches and all appear to be functioning when tested both via the LED and being recognized by CM.
When first initializing, my z goes down and hits the spoil board and then goes up but doesn’t reach the homing switch - then just stops and gives me the error below.
I’ve tried to manually job the z-axis and will really only go down. If I try to go up, it may go up slightly and then goes down. After reading through some other posts, I’m having the same issue as many but I’m unclear on how to resolve as it sounds like it may be some config setting but I’m lost on how to remedy.
Anyone have some insights for me?
"HM009: The machine could not find the homing switches.
This could be caused by:
- Mechanical problems jamming a machine axis
- A malfunctioning homing switch
This is equivalent to GRBL Alarm 9.
