5 Pro Initializing problem. After a mistake
Ok I did a dumb thing and don’t know how to correct it. The machine initialized with no problem and I used Jog to fast move it to front center. Midway I noticed I had left something on the bed and decided to use the stop button in the carbide motion software. The machine was moving diagonally at that time. When I tried to reinitialize I see that the gantry is out of square and binding causing error codes. I disconnected both y rail motors and loosened the four gantry to y rail bolts and brought both y rail gantry mounts to the front stops. I held the gantry against both stops and tightened it down. After reassembly it drives itself out of square again and errors out. Any one else run into this.
Check for loose stepper motor connection or a loose stepper coupling.
I will ad to check any of the ballscrew nuts in the carriages.
Solved: This turned out to be the wire for the left y proximity switch pulled out of its terminal on the control panel. Thanks
