I received my 5 pro 5 days ago, my first cnc dealings ever, so this is all new to me. Been running for a couple days with a few issue that i was able to get help with here. Been using a trim router. My vfd spindle came in yesterday so i decided to install,when try to connect to cm there is no option in settings. Everything is installed as per instructions. Can someone please help me out,beginning to not like my new purchase very much! Please dumb it down for me,im a beginner.
Thanks!!
You will need to go to the Setup Wizard and reconfigure to enable the VFD:
Thank you,I will try that. The instructions i downloaded from c3d are kind of vague,mentioned all machines compatible with the spindle except the 5 pro. Thank you again for responding!!
Will post the results
Thank you for help! Works great! I still have a lot to learn!
Thanks again!
