If I use a 60-degree bit to v-carve a sign, then, without removing the piece, decide I would rather use a 90-degree, will the program follow the same path and be unnoticeable that the 60 was first? Or is there some principle here in the CNC world that wouldn’t let that happen?
You should be fine, make another tool path for the same geometry and set the bit for the 90 deg V bit and then run the simulation. Watch your depth of cut to ensure it matches the first cut or a hare deeper. Ensure you have enough material on you stock to carve a wider path with the 90 deg V bit.
Do not reset X/Y/Z zeros.
That was the answer I was hoping for
The 60 degree V-tool will have cut deeper and removed more material than the 90 degree V-tool.
It might have been okay if you were following an obtuse tool with one more acute.
What @WillAdams said.
So there are two options here. If you re-run the exact same G-Code, but use a 90 instead of a 60, then it will cut as deep as the 60 did, and everything will be oversize. It will be particularly noticeable on smaller details.
If you do a 60 deg first, then change the project to use a 90 and run that, The 90 will make absolutely no change to the project.
