Carbide 3D 65mm VFD Spindle Kit - 110V Asking 500 local pick up
Everything needed to upgrade your router to this spindle kit is included plus the deep sweepy. This kit was only used about 200 hrs until I upgraded to 80mm Spindle kit. “This spindle is 65mm in diameter, so it should fit any Shapeoko 3, 4, Pro, or 5 Pro. That said, it is significantly heavier than a standard trim router, so we prefer to pair it up with an HDZ but the Z-Plus works well too. We do not recommend adding the VFD Spindle to the original Shapeoko 3 belt-drive Z-Axis”
