Can someone with the 80mm spindle tell me the length of the power cord that comes with the kit? I’m trying to figure out whether I need to order a longer cord, move my outlet, move my machine table, and so on. Thanks!
Mine is 5.5 ft.
more characters so it will post
Thanks for the quick measurement and reply, @Bee
I mounted my VFD under the machine, and stooping down and reaching under got old real quick. I got a the below switch and wired in a an addition 10’. My cord is 14-3. The switch is mounted on the back right leg about a foot down. My VFD is mounted to the inside of the left leg.
It will be cheaper than moving an outlet, and well within limits of 14-3 wire at 220v - 15A, which is 50 ft according to the first link below. As always hire a qualified electrician if you have concerns.
Switch
http://amazon.com/dp/B0H1WB4VJQ?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
