A cover for back of gantry to block dust/chips from getting into the linear screw
HI all,
I was cutting some aluminum and it created a holy mess on my S5 pro. Bed and the back of gantry. I was using WD40 spray and my compressed air nozzle. I am wondering if any of you have put some sort of cover on the gantry to block the chips from getting into the linear screws on the gantry. seems like there is space behind the Z assemply to do this. Any idseas?
Also, if i have the air stream mounted its still goint to cause a lot of mess, correct?
Thanks,
Mani
The usual term for this is “way cover” and we’ve had some folks make them:
https://community.carbide3d.com/search?q=way%20cover
Is cutting dry an option if you use the air blast setup? I sacrificed a sweepy on my last alu. project and it managed the chips quite well.
