A likely easy fix (for any one but me) for a 3d File
I created a 3d file for a nameplate. A friend wanted me to make it for a Cardiologist who saved his life.
My idea was to create a rounded border with a .2" pocket around two images and a name.
I believe I have done that, but the simulation seems to show the entire project less than the thickness of the wood.
I tried multiple changes in 3d Modeling and can’t seem to get it right.
What do I need to change?
Critiques of the file would also be appreciated. I attached the file for review and possibly your amusement.
Rick Heart Test.with inset 3d.c2d (2.6 MB)
The file is set up for 0.76" thick stock:
the high point seems to be ~0.55" or so:
If we draw in a bit of geometry:
and model it to the thickness:
We see:
Since the base is modeled:
and apparently being cut away from:
if we want the design to be thicker, then simply reducing or increasing one or the other should work:
