I’m a computer guy, and I have uninterruptible power supplies (UPS) all over my house. I buy new ones for my computers, and the old ones find homes on TVs, clocks, etc.
I’ve owned my Nomad for over 5 years, and without even thinking about it I have always had it plugged into one of the hand-me-down UPS. I am currently in the process of building my Shapeoko, which will be in the garage in it’s own enclosure. I’ve been working on the enclosure and Shapeoko for nearly a month now, and I am finally at the tail end of the build to the point that I should run my first project this weekend. But back to the point of this conversion, the UPS…
I put an older UPS (with new batteries) inside this enclosure, and one of the things I have in the enclosure is a simple AC powered fan. When I was working on the wiring for the enclosure I turned on the fan, and then unplugged the UPS from the wall (to simulate a power failure). The UPS switched over to batteries and the fan (and light) continued to work just like it should have. Except I (easily) noticed the fan SOUNDED different, slower. I could even feel the air flow difference. I plugged the UPS back in and the fan spun faster, unplugged and it spun slower.
This sent me down a rabbit hole, but I can tell you this observation was not unique to that specific UPS unit. I observed this on 4 of the 5 UPS I tested. But to simplify this discussion, here are the results I recorded when running the Carbide router off that original UPS (router power/speed to low/1).
When the UPS was plugged in, running off AC power. Here are the numbers I recorded…
118.4 volts
2.41 amps
76 watts
276 volt amps
59.9 hz
… and when the UPS switched to battery (pulled the plug).
104.8 volts
3.16 amps
95 watts
344 volt amps
hz showed an error msg (not a ture sine wave ups).
And the sound, the router was not consistent, it sounded slower and it sounded like it was struggling. I stopped the test, and was disappointed. These were the results using an $120 class UPS, my initial testing (with the fan) got different results on my most expensive UPS ($400 range). So I used that most expensive UPS and the Carbide router, and of course it did significantly better, no struggling, no audible difference in power (as my credit card screamed in pain).
So what is this telling me. On one hand I’m assuming that ANY UPS is still better than no UPS, especially if the power outage is very short (or a brown out situation). But I didn’t expect the routers performance to drop. A badly timed power droop or blink could still result in a CNC failure. But do I use the older UPS knowing this, or do I spend $400 on a UPS… probably not.
I am not an electrical engineer, would LOVE to hear some options of those that know more about this stuff.
