Hello, is there anyone who could help me add a bit amana 46473. Thank you very much.
Carbide Create does not know how to handle tapered ball nose bits. However you can just enter it as a round nose bit the size at the base of the tool.
Here is the specs for the Amana 46743
46473 CNC 2D and 3D Carving 6.2 Deg Tapered Angle Ball Tip x 0.5mm Dia x 0.25mm Radius x 26.5mm x 6mm Shank x 75mm Long x 3 Flute Up-Cut Spiral Solid Carbide ZrN Coated
#46473
Specification|(a°) Angle|6.2°|
|(D) Diameter|0.5mm|
|(R) Radius|0.25mm|
|(B) Cutting Height|26.5mm|
|(d) Shank|6mm|
|Overall Length (L)|75mm|
|Type|Ball Nose, ZrN|
|Flutes|3|
So the tip diameter is .5MM so enter it as a ball tip with .5MM diameter. Just be careful if cutting 3d that there is nothing above it when cutting because the larger diameter body will cut into any over hang.
