Add Amana Bit 51446-K
This is my first time adding in a bit that doesnt have a file I can import. Can anyone help me with what numbers to fill in to add the Amana Tool 51446-K SC Spektra Plastic Up-Cut Bit 1/8 D x 3/4 CH x 1/4 SHK into Carbide Create? I saw the post below but it didnt seem to include the 51446 series bit.
I also see this from the Amana site but then I dont see the 1/8" (0.125) bit diameter listed.
https://www.amanatool.com/51446-k-solid-carbide-cnc-spektratm-extreme-tool-life-coated-spiral-o-single-flute-plastic-cutting-1-8-dia-x-3-4-x-1-4-shank-x-2-1-2-inch-long-up-cut-router-bit.html
And just in case, here is the exact bit I bought (if it links correctly)
Thanks in advance for the help!
Shouldn’t this be very similar to the Amana 51411-K .125" Single flute up cut that Carbide3D sells? The difference is shank size (1/8 for 51411-K and 1/4 for the 51446-K) and cut length (1/2 inch vs 3/4 inch.) Speeds and feeds should be similar (the Amana guidance is based on cutter diameter and they have the same diameter). You probably can start with the 51411-K info and make changes from there.
John
Starting from the 51411-K numbers like Stankus said makes sense. With plastic, if the chips look melted or gummy, bump the feed up or drop the RPM a bit.
