Adding tool in carbide create v8 fails
Simply adding a 1/4 tool ( i used .250) and when I hit ok it changes the tool diameter it 0.0098 and the plunge rate to 0.3150 and I get an error that the “Plungerate” must be between 0.500 and 10000.000
I did a test and entered a tool using metric measurements and it was ok.
Any ideas, I fooled around with the , verse period thing but that did not work.
Enter all of the units.
The tool addition dialog is broken - if the units of the project do not match the units of the tool, then it applies un-needed imperial/metric conversions.
So, change your project units to inches, add your tool, then change back to metric.
