I ran a 1.25 leveling bit and got lines as the bit over lapped. my spindle point if off but how do you adjust this? The screws that hold the router clamp to the z plate are not accessible when the z plate is on the machine. Looking for suggestions. Thanks
There should be holes in the back of the plate which allow access to those screws.
Thanks Will I will take a second look. Appreciate the help
Please watch Winston’s YouTube video on exactly this problem. (because you still need to worry about the other direction (X and Y)
