Basic question here. I’m doing multiple runs of the same job and want to adjust the Z height slightly on the fly without lowering and fine tuning the tool. If I just want the zero raised a thousandth is there a way to open the zero tab and simply enter an offset manually? Or do I need to position the tool to where I want it and then clear out the Z offset?
You can also do this on the set zero page; just enter the desired number in the Z field, but be careful; you are entering the position relative to the zero so if you want the zero raised a thousandth you enter a number a thousandth LESS than that currently displayed! (also, you must hit the enter key for your change to take effect)
Thanks! That’s what I thought would work. I tried this but I think it didn’t work because I entered 5.999 and that would’ve been mm and too small to register (I was thinking in thousandths and using metric)
