Correct, no hubs.
FYI, my pc has 8 USB ports and I have tried all of them with multiple USB sticks. Still cannot boot any Linux I have attempted.
Correct, no hubs.
Did you turn on the option is BIOS to boot from USB?
What application are you using to write the install thumbdrives?
(assuming you have downloaded an *.iso file for installation- i.e. for Mint “linuxmint-22.3-cinnamon-64bit.iso” or Debian “debian-13.4.0-amd64-netinst.iso”).
Yes, sir. Thank you for the assistance.
Used AnyBurn and BelinaEtcher plus I’ve tried Ventoy, no luck with Ventoy either.
Here’s a list of the distros I’ve tried…
“D:\Documents\Personal\Computer\Linux\debian-13.4.0-amd64-netinst.iso”
“D:\Documents\Personal\Computer\Linux\kubuntu-25.10-desktop-amd64.iso”
“D:\Documents\Personal\Computer\Linux\linuxmint-22.1-cinnamon-64bit.iso”
“D:\Documents\Personal\Computer\Linux\linuxmint-22.3-xfce-64bit.iso”
“D:\Documents\Personal\Computer\Linux\pop-os_24.04_amd64_generic_23.iso”
“D:\Documents\Personal\Computer\Linux\TinyCore-current.iso”
“D:\Documents\Personal\Computer\Linux\ultramarine-plasma-43-live-anaconda-x86_64.iso”
“D:\Documents\Personal\Computer\Linux\Zorin-OS-18-Core-64-bit-r3.iso”
I feel your pain… I knew (and really still dont) nothing about Linux before installing Mint Cinnamon on an old laptop with the intent of running Carbide motion for my SO4. I did a bunch of reading and research on linux and ended up using ChatGPT on a second laptop to do the installation. Every time something didn’t work I went back to ChatGPT and told it what was going on and was presented with a solution which may or may not have worked. It took a while but eventually I got everything installed and working.
You don’t have any other USB devices plugged in to the computer while trying to boot from USB. The error message you posted a few posts back suggests an audio device that isn’t compatible. I usually just have a keyboard/mouse plugged in, and the USB drive I’m booting from.
I really don’t understand why this isn’t working for you, usually Linux just works. Nothing about your system specs suggests anything that would prevent the system from running Linux.
@NathanS21, I think freq in this case is “file request”
Many years back I tried Linux and it loaded up perfectly. I have no idea. But my local “Voodoo” friend suggested sacrificing a chicken over my SSDs. ; ) What could possibly go wrong?
Also if you have not checked or done already change the boot sequence, ie USB then HD.
Yes it is USB the WIndows
