Good afternoon, I wanted some help clarifying how to rezero when doing a tool change. When splitting the advanced v carve file how do you reset. Do you reset to the original x,y,z zero or just put the bit in the router with the bit collar on. ( I don’t have a z probe so using manual methods). I’m confused because I had to change the z retract height when splitting the file or else it wouldn’t retract enough to do a tool change. Any help would be greatly appreciated.
The Advanced V carve is intended to be used w/ a BitSetter.
Yes but if you split the file you can use it. I was wondering about the rezero process.
If the file is split, you can re-zero Z only.
Thank you I will give it a shot.
