I had posted a thread some time ago about weirdness I was having with regards to the machine going a little haywire after cutting a part, jogging and resetting x/y and cutting another. Or just after running a zeroing macro and trying to cut the part.
It turns out I think the problem was all in the Vectric preprocessors for creating the gcode files. This last weekend I was cutting some templates for something I sell. I cut one, jogged the machine and reset x/y, then tried to cut another and the machine started moving in ways that required cutting power.
So I looked at my gcode file, which has been around for a while, and see there is no G90 or G91 in the header. I then pulled up the version of Cut2d that is currently loaded (newer version that what was used to create that older template.gcode file) and created a new gcode file w/ out making any changes, and now there is a G90.
So I think what was happening is when jogging, the sender sends a G91, and so the machine stays in relative mode, and when I ran the program, it didn’t send a G90 but needed to have.
There was a period of several versions of Cut2D that came w/ bad preprocessors, they kept messing one thing or another up. Hopefully that is behind me now.
Is that an old version?
That’s frustrating…I think they should all jog and then send the G90 in the same click.
Even better if they’d use grbls newer $J style jog which doesn’t affect the motion mode. Carbide Motion does it that way. I wish CNCjs did.
It is an old version, I’m using a newer one, I don’t know if it changes the coordinate system back to whatever was set. I have an old version of Grbl on my machine, no homing or limit switches, etc. I really don’t need the extra features, provided my gcode files are properly written.
