Well i am still working on my enclosure but am getting close to throwing rooster tails with aluminum
I read here every day and do see that an air blast will help evacuate chips. I am also considering using water mixed with alcohol.
I am curious if the sweepy suctions up aluminum similar to wood chips?
Any success with a dust deputy and a shop vac?
Thinking about bellows as well, i have been reading the posts about that too.
So you folks that mill aluminum what are your chip evacuation methods, thoughts?
Thanks!
WillAdams
(William Adams (Carbide 3D))
November 3, 2026, 3:33pm
2
Yes, the Sweepy will vacuum up aluminum chips — but it will get scratched up and become cloudy:
If that’s okay, or you can view it as a consumable, it’s fine and for me, worked well.
I will note that I added a pre-cyclone in an effort to keep hot chips out of my wood chips, and so that they could possibly be recycled.
Tod1d
(Tod (with 1 'd'))
November 3, 2026, 6:05pm
3
As Will’s picture illustrates, you’ll need to comb out the bristles afterward. But I’ve used the sweepy with dry aluminum cuts & it works well. I haven’t tried it with coolant, but I’m betting it’s a much bigger mess. And positioning the coolant with the sweepy in the way could be troublesome.
Now I prefer the coolant, so it’s just a bit more cleanup afterward.
jtclose
(Jim Close)
November 3, 2026, 6:12pm
4
Coolant or ( any liquid )makes cleanup much harder. Acts like glue/suction.
Vacuum does not have the same effects.
Eric217
(Eric L)
November 3, 2026, 8:08pm
5
I use the sweepy with air assist, I just cut out a section of the brush for the tube to sit. The vacuum collects 99% of the chips.
WillAdams:
pre-cyclone
Is the clear sweepy bottom half available for purchase or printing?
What is a pre-cyclone, I googled it but did not find anything appropriate.
Thanks
To all… Thanks for the responses
WillAdams
November 4, 2026, 12:38pm
7
No, except for the Deep Sweep.
A pre-cyclone is a second one added in-line before the main one.
It was a ghastly temporary setup/hack.
