Hypothetical situation: If you are 25 minutes into a 40 minute cut, and your beautiful 4yr old daughter walks by and puts her hand on the touch screen, and in doing so happens to stop and cancel out the job you are currently working on, is there a way to pick up where you left off? Again, purely hypothetical here….
Carbide Motion does not currently have a feature for this.
If you know the line # you could edit the file, preserving the preamble and resuming the cut at a plunge from safety/retract height.
Alternately, just use feed rate override to hurry through the already cut portion of the file, then slow down to resume.
If there were multiple paths, and your beautiful daughter accidently touched the screen as she was giving you loves, disable the paths that completed. Re save, and start.
Good Luck
