I’m trying to figure out how I can have an angled cut path with a 60 degree vee bit going from 1/8" deep at one end of a X axis to 1/4" deep in a straight line along the same X axis about 4" from the beginning. Is this possible? I know it takes some time to draw it up using a different software package than in Carbide Create.
This is not possible in Carbide Create.
You can sort of do it by drawing segments, each of which cuts to a different depth, then having a final toolpath which one edits in the G-code to cut at an angle if the steps aren’t acceptable.
I actually use this as an example in a project I’ve been working on:
but it’s not to a usable state (in particular, it needs to have a robust way to handle multiple passes), and I doubt anyone else would be interested in it, and it’s currently getting re-written (again), this time in pure Python (which can then be called from OpenSCAD if desired).
The real work-around for this would be to model the cut in 3D using Carbide Create Pro or some other 3D tool.
Seems pretty possible to me…
Draw a 0.072" radius circle. 4" away draw a 0.144" radius circle.
Connect the tangent points & unite, or trim & join.
Run a V-carve with a depth per pass deeper than the total depth.
@Tod1d, That is brilliant!
Easy on that “brilliant” stuff!! ![]()
To be fair, it’s not a very pretty toolpath, and it has a few corner picks (sewing machine moves).
Way cleaner to create a contour no offset on a 4" line at 0.125 deep, then just add the one Z value at 0.250.
(Design File: )
(stockMin:0.000in, 0.000in, -1.000in)
(stockMax:6.000in, 2.000in, 0.000in)
(STOCK/BLOCK,6.000, 2.000, 1.000,0.000, 0.000, 1.000)
G90
G20
(Move to safe Z to avoid workholding)
G53G0Z-0.197
(Toolpath: Contour Toolpath 1)
M05
(TOOL/MILL,0.125, 0.000, 0.000, 0.00)
M6T102
M03S10000
M0
G0X1.0000Y1.0000
Z0.0098
G1Z-0.1250F8.0
X5.0000 Z-0.250 F20.0 (Add the Z here)
Z0.1575
M05
M02
Steve,I have to agree with you that is Brilliant from Tod.Trying it now
