Designed this today. What do you guys think?
Well made and purty as a rubber ducky!
good stuff, better grip and protects wire from stress!
if you publish this STL on thingiverse or elsewhere, I will download and remix so it would just fit over my existing cable. maybe slot on side or may it two halves that you glue together.
Purdy, but cheaper and easier to get magnet with hole and screw to current clip.
Cheaper and simpler yet. It took less than 10 seconds to build but it certainly is not as pretty as yours.
Thats a 0.25" x 0.25" x 0.125" magnet
Good fix. I have a Shark cnc and they have a magnet on their touch probe. On my Shapeoko the clip goes flying every time I use it at least once. I need to fix it with a magnet.
