ok so I have set up a dedicated computer for my machine. it runs windows,
I have create pro on my apple laptop. I wanted to copy some of my Amana tools to the windows computer. I have found the files on my laptop, and saved them to a flash drive. when I went to find the same file location on the windows computer I couldn’t find it. can anyone help me find the correct place to put those files?
*side note I won’t have access to this machine and computer till next Thursday (it belongs to a robotics team I mentor) so I may not have answers to follow up questions on the windows side.
im not a big fan of cloud stuff generally. I just want to be able to copy a file from my program files on one computer to another. or import databases like you could with vetric.
Yep- drop it in the same place on Windows. You might have to create the subdirectory, I don’t recall if we create it by default. @WillAdams has a better memory than me.
so I’m pretty sure it was created by default by at least one version — it might be that I made a user tool library (causing the folder to be created), then deleted it and the folder persisted.
Best thing to do is to make a user tool library with at least one tool — that will ensure that the folder is created with the correct permissions.
I installed CC815 on my Macbook Air tonight and there is no “About” option under the Help menu so I cant get to the tool .csv file. I can open the tool database under Edit/Show Tool Database.
Any suggestions?
