I am going to display some flags I make at a local craft show on a 6’ or 8’ table. I’d like to “stack” two flags together, a 28" wide flag and a 20" wide flag. I’m having a hard time designing it and want to just carve something on the machine to make it easy. I can’t really explain myself very well, so here are some pics.
you might want to make the vertical lines slightly sloped so that the flags can “lean back” a little bit… to avoid them falling forward too easily…
doesn’t need MUCH of a slope for gravity to help you there but zero feels a bit risky
Perhaps I should design a few different variables and cut them at the same time to see what works instead of assume it works and cutting several that ultimately don’t.
(In this case, a “dummy” is a folded up set of signatures to verify the thickness of a book (or magazine) block for binding)
I go through a lot of cardboard cutting quick prototypes to verify dimensions and proportions and angles — helps a lot — then a quick sample in MDF or some other inexpensive material before committing w/ the actual stock.
