Arc endpoint error
I am running a file of a flag with an eagle. The flag ran fine but when I tried to cut the eagle I get the “arc endpoint error” and line 202695 (although that number has varied with each attempt). Help
Vectric? What post processor?
I’m assuming you’re using inches when you post. Use a metric post processor.
Can you share your gcode?
Yes Vectric version 11.014. The post processor is Carbide Motion ATC (inches)(*.nc)
Make sure that you have updated to the most recent version and then try the metric post as suggested by @neilferreri
If that doesn’t work, check in w/ Vectric tech support.
I’m not able to get the gcode for you
Will, how do I do an update?
Vectric is supposed to notify about new versions — also you can check your software library on their site — Vectric tech support should be able to assist.
Ok. I thought you meant on the Shapeoko. I have the latest version of Vectric.
