spinner
(Frank)
September 18, 2021, 8:41am
1
Hi again.
So I continued to assemble my Shapeoko 4 XL and finally reached the step where I mount the hybrid table.
Only I think I´m missing the screws to mount the aluminium parts and received twice the amount of bolts for the MDF.
Or am I overlooking something?
Julien
(Julien)
September 18, 2021, 8:45am
3
I’m not sure but definitely contact support@carbide3d.com to let them know
WillAdams
(William Adams (Carbide 3D))
September 18, 2021, 12:41pm
4
As per:
https://docs.carbide3d.com/assembly/shapeoko-4/xxl/shapeoko4_xxl_assembly_guide_07-08-21_v1_web.pdf
you are missing:
O M6×10mm Flat Head Screw 80
Let us know at support@carbide3d.com and we’ll get these out to you as quickly as we can.
You should have a couple of spares in your “Extra Hardware Bag” — they should suffice to get this part of the assembly started, but you’ll need to wait for the balance, and unless you have a local hardware store which sells by the pound, kind of pricey to get these locally and not wait.
spinner
(Frank)
September 18, 2021, 6:38pm
5
Thank you for your reply.
I went out and picked up 60x M6x20 - as they did not have any M6x10 - for around $8 and they seem to fit and luckily they don’t seem too long.
Not sure if they’re a perfect fit though as I think US countersunk screws are normally 82° whereas european - where I’m situated - are normally 90°.
Everything seems snug and tight so unless you recommend still using the M6x10 I guess I’ll just leave it like this.
WillAdams
September 18, 2021, 9:16pm
6
Metric screws shouldn’t have a different countersink angle — they’re supposed to all have 90 degree countersinks.
82° only happens w/ Imperial hardware which we don’t use.
system
(system)
Closed
October 18, 2021, 9:16pm
7
