Assembly Legs for 5.1
I just received my shapeopo 5.1. Im waiting for the legs. Is it best to wait for then legs to arrive before assembling or can part of it be assembled before they arrive?
My reading of the instructions is that this is documented as being done during initial assembly:
I suspect it could be done after — if one had a taller table (ideally two which could be repositioned) and a couple of helpers who would assist with:
  • positioning the machine on the tables so that the legs could be attached
  • lifting up the machine vertically
  • removing the two tables from underneath the machine
  • gently setting the machine down on the legs without torquing or twisting
Having had to move my machines around, that would want at least three people…
Thanks. I think I will wait until legs arrive before assembly.
