Just got my new Pro XXL in and I was wondering how everyone attaches theirs to the table? I built a new table for it was a melamine surface but I’m worried now that it will move around too much.
Thanks in advance,
Francisco
Thanks in advance,
Francisco
We’d generally recommend that you block it in to constrain movement if you want, but don’t bolt it down. If you bolt it down, you can twist and warp the frame to the table.
You could also apply some adhesive foam to the bottom of the frame if you want to add a little friction.
Hadn’t thought about twisting it. I’ll see how it does and maybe thin piece of weather strip to provide some friction.
Thanks for the quick response!
Two L shaped wood brackets in opposite corner on the outside would keep any accidental movement of the machine.
