I’m using Carbide Create 474 with a Nomad. In Job Setup, stock size is set to 8 x 8 inches. When I upload a background image (jpg or png) that is also 8 x 8 inches at 96 DPI, I expect the background to perfectly match the work area, but instead the background image imports MUCH bigger. After trial & error, I find that scaling the image to around .2645 gets it close to matching, but not exactly.
How do I create a background image that will match up with the 8 x 8 work area automatically upon import, with no scaling or other manual adjustments required? Is the background feature looking for a different DPI than everywhere else?
