Best Way to Power Down Machine
When one is done with the 5 Pro for the day, what is the best way to power it down? The machine gets sent to the home position (back right corner) and then I shut off my power strip where the machine is plugged into. I am not sure what is in the controller box, so not sure if shutting off the switch on the bottom of the controller has the same effect as just turning off the power strip.
Thanks.
You can kill power from a power strip, or from the machine controller, both options are valid. (In our shop we use a power strip because we have lighting plugged in there too, so it’s just easier)
Thanks Rob. Much appreciated to get the official answer!
