I use a touch screen to control motion while printing. Is there a way to control the size of buttons to make them easier to press?
what size touch screen?
I’m using a 24" Dell All in One for my Pro, and have no problems, but I can imagine it would be on a 10" screen.
Note that there are several considerations here:
- which OS — Windows or Raspberry Pi?
- physical screen size
- pixel density of the screen
- screen scaling setting in Windows for the application (not sure if Raspbian affords any settings for that)
Screen size a 10" touchscreen running on windows 10. Everything just uses the top quarter of the area. Jogging is the issue. I am running a Intel Stick and while it runs motion it won’t run creat!!???
Is the Intel Stick 64-bit? I believe that’s the system requirements difference between Motion and Create, the latter needing it.
That may be the problem. Is there a way to get it to run anyway?
