Bit for Fine Detail Contour on PVC
Good Morning All,
Hoping for a solution for this. I’m cutting shapes from PVC vinyl. I’m fine with using the 1/8" bit for most of the work. It cuts beautifully. It’s a single flute O upcut bit.
I need to cut smaller shapes and need to cut with a 1/16" bit for it. What do you recommend? I’m cutting through .48". I can’t find a single flute upcut bit that can cut that deep.
Any recs?
Garr Tools sells a long-reach 1/8" tool, 2-flute and quite aggressive — they might have something along those lines, or check w/
@TDA might be able to advise.
This is the closest I could find. https://drillbitsunlimited.com/products/0-0591-1-50mm-x-12mm-flute-length-single-o-flute-carbide-end-mill-tin-coated-m130?
https://www.ebay.com/itm/153845536102
Maybe consider using a 30° or 15° vee bit if the application allows. When I first started my CNC journey, I struggled with wanting flat/clean sidewalls on my carves but discovered that an advanced v-carve with a 30° vee bit accomplished what I needed… with the added advantage of sharp inner corners.
Example:
Ooohhh, this looks good! Thanks for the recommendation! Just ordered!
That’s a very interesting idea. I’m going to try this! Thank you for taking the time to help me!
One difference. I am using HDU and haven’t used PVC vinyl ever, though I also use this method on wood. So…TEST TEST TEST!!
Oh, wow! Perfect! Thank you so much!
