Bit not starting at specified Z in Advanced V Carve
Hi all,
Going to do a simple advanced V carve.
I dont use Bitzero and prefer to manually zero.
After I manually Zero with the endmill Im using. I go ahead and run. It goes through the motion, jogs over to the bitsetter, and when its time to start cu
Westfield Fire Inside ladder.nc (151.8 KB)
tting, it doesnt cut starting at my specified Z. It starts much higher.
Any ideas as to what is causing this?
Check that the Z Zero in your design matches the Z Zero you set on the machine. You get this behaviour if the design is set to bottom-of-stock (wasteboard), but you zero off the top-of-stock.
Also, for the future, the design file is way more useful than the .NC file for diagnosing problems.
Sorry, heres the design file
westfield ladder advanced v carve.c2d (1.1 MB)
Yea, the design is zeroing at top of stock.
After setting Z, and after manually changing the tool using the “Load new tool” button, what happens if you check your Z-axis by using the Rapid Position button to move to Z+6mm?
After I load new tool, its about +13 mm higher
So so weird!
Did you load the new tool using the “Load New Tool” button?
What @WillAdams is trying to get at is never change the bit without the software or the load new tool button. If you manually change a bit the BitSetter and the previously Z zero are not synchronized. Always be prompted to change a bit and never jog to the front and just change the bit.
