Bit plunges beeper then is programmed
I need some help(again).
I will design a cut path that is only going 0.100 inches but when I land the g-code and start the job the bit plunges to at least .5 or .75 of an inch.
I have looked over my setting and I did not find anything wrong with my g-code.
any help is greatly appreciated.
Things which will cause this:
  • disconnect between where you are setting the origin in the file and how you are setting origin relative to the stock
  • changing the endmill w/o using the interface in Carbide Motion
  • lost steps on retract due to excessive safety/retract height
  • lost steps due to an electrical wiring issue
Please check these things — if you don’t find anything obvious to address, write in to support@carbide3d.com
Give this a read:
https://carbide3d.com/blog/unexpected-z-axis-plunges/
