Yesterday while doing a resurfacing on a cutting board, I had my DOC too deep and the machine came to a halt causing an error alarm. After resetting the DOC, now the bit runner does not start the router. I do hear an audible click when I hit start. I plugged the router into a separate outlet and it works so I have to turn it on manually.
Any suggestions
Thanks David
Which BitRunner version?
If it has a fuse, check the fuse?
Bit runner standard. No fuse
Check in at support and we’ll work through this with you there.
Ok I have signed on , on the web
and also by phone.
Thanks
Fuse was the problem
Thanks
David
