Hi everyone,
Let me state clearly I am a NEWBIE. ![]()
After spending 3 days (partial days) of assembling my Shapeoko 4, lots of fun.
I went through all the initial tutorials for learning about the machine. I did the Hello World project with the marker. During this project I Disabled the Bit Setter (FYI I don’t have the cooler BitZero.). This worked fine after I zeroed z a little lower so it wrote on the paper.
Next up I decided to try a little project - cutting a placemat (oval) out of 1/16 inch Plexiglass. I added a stock starfish to the project and used the V Bit, Ballnose, and Mill End bits to engrave the starfish and Final Cut the Oval out of the stock. I converted everything to mm’s so I could be more accurate. 1/16th inch = 1.5875mm The Starfish uses depths from 0.30 mm to 0.50mm.
After Initializing the machine and re-Enabling Bit Setter, setting Zero’s (x,y,z), I even used the cool paper trick to ensure that the Z axis was just touching the plexiglass. I was excited to give it a try. During the Initialization I installed the 302 V 60 degree Mill End when asked for bit change, it did us the Bit Setter during the initialization which gave me some confidence. I then hit Run and it called for another bit change, which I simply resumed, it then did the Bit Setter again (Cool!!!).
Excitedly watching as it moved to the initial Node. I watched as it slowly moved down and made contact with the plexiglass, and then the horror as I watched it plunge through the Plexiglass, into and through the waste board, and finally into the Aluminum T-Track.
Unfortunately I was at the front of the machine watching in excitement and it took me a moment to move around to the side and hit Pause, Stop, and the Red Stop which finally stopped everything (the Pause and Stop seem to be very delayed, another question for later). The 302 V broke off the tip and some of the aluminum fused to the edge of the Mill(bit). Luckily I am in the 30 day window and Carbide is great!!!
But now I am terrified to use the Bit Setter because I can’t seem to explain what I did wrong.
Any assistance is appreciated. FYI I have been told by Support that Carbide doesn’t have setting for the 302 V and hard plastic, but given I was trying a 0.3 mm cut of 1 inch in length they indicated that it was probably ok. Given that the plunge cut through the plexiglass was very clean (no chipping or cracking I thing I would have been safe if it had stopped at the 0.3/0.5 mm level.
I have uploaded the C2D and NC files, incase I missed something.
Plexiglass placemat with Starfish design.c2d (653.0 KB)
Plexiglass placemat with Starfish design.nc (339.4 KB)
Is there anything I can do before hitting run to ensure that all the setting are right for the initial?
Aka what are the initial setting (depths), before doing it what would be the initial node movement, etc??? Any other diagnostic stuff I can do to gain confidence in the Bit Setter and the User???
Thank you,
The DougMan
