Why does my bit setter go to the back right of the machine to look for my bit setter after I hit load tool? My bit setter is in the front right, not the back right.
Because you enabled the BitSetter w/o configuring the location.
Power up, connect to the machine, go to Settings, disable the BitSetter — that will allow you to initialize, then configure per the instructions:
thanks, that worked for me.
