Can some one point me to where I can find a tutorial on how to use bit setter
Try this video as a starting point, perhaps?
Thanks Peter it was helpful
But it did not show starting a new file and going through the steps of things that happen.
jeff
I have seen this video Just looking for a video that would show the steps and screens as the pertain to what screens show up when there is a tool change.
jeff
There are no new screens, per se.
There is a “Tool Change Required” dialog that pops up like in this tiny picture from the BitSetter documentation:
If you are changing tools in the job, it tells you the number of the tool it wants.
That’s pretty much it.
Jeff:
I find this video helpful. Skip by the first two minutes as it only is pertinent if you are using Vetric V-Carve to create your g-code files.
Bill
