First and foremost, contact support@carbide3d.com
You need to check if your Bitsetter is working:
- when you push the bitsetter buttton manually, does the LED light up?
- if so, open Carbide Motion, connect but do NOT initialize, then go to the Settings page. There is a line there called “GBRL active input pins”. Does it display “PROBE” when you push the bitsetter? If not, something is wrong in the bitsetter wiring
