Here we go, the first actual test that makes sense I will do this and see.
Also, there is no issue with going down far enough, there is no slippage as the cut would fail with a slippage.
This has been the case since I started using a bit setter, which is why I initially though that I am doing something out of sync.
Ok… so… after doing the test mentioned above… I needed to cycle between the bits using the Load Tool sequence(after setting the Z manually) a couple times as it was still off a tad. Now they are measuring the same z height when switching. I will do a test cut here in a bit to see if it still holds true.
I use VCarve pro 11 and I use the Shapeoko (inch)TOOLCHANGE (*,gcode Clint is this what you use. If not could you tell me which one you use.
Thanks Jeff peters
I use the mm version of that. Very recently, I have switched to the carbide atc mm post processor. Which ever you choose, use the MM version and not the inch. The inch can have issues with curves.
