After replacing both Y axis motors and one of the. wiring harnesses due to damage, the bit setter no longer operates. I cannot get it to turn on. I have tried disabling and re-enabling the bit setter and going through the initialization process, as well and turning the machine off and back on. The lights do not come on and it does not respond to pressure.
If you’re under warranty, check in at support@carbide3d.com
Post photos showing how it is mounted, wired up and connected to the controller?
